It is currently Sun Aug 03, 2025 6:06 pm
PostPosted: Mon Jan 12, 2009 3:03 pm
First name: Matt
Last Name: Meyer
City: Muscatine
State: Iowa
Zip/Postal Code: 52761
I've been following the thread on a cheap controller with great interest. Is it possible to make these setups control two blankets simultaneously?
PostPosted: Mon Jan 12, 2009 6:37 pm
I would think no. That is if my assumption that you are talking about 1 controller and 2 blankets is correct. In this case you would have twice the amount of juice (amps) going through the controller. I would think that this would cause the controller to overheat and then melt or burn up....or both...now, perhaps it would be relatively 'easy' to modify the internals of the controller to handle this load, but it would be a tad safer and easier to just use 1 device for each blanket.
PostPosted: Mon Jan 12, 2009 7:10 pm
If the controller was sized properly to handle the load (amps) from two blankets then it would not be a problem. The biggest issue I see is that you would only have one thermocouple to read the temperature so that one blanket may run too hot or too cold. I would use dual controllers
PostPosted: Mon Jan 12, 2009 7:43 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
As long as your external relay or the one in the controller can handle the double amps it should not be a problem, the blankets should be the same and I would be careful at first that the blanket on the opposite side of the wood does not heat too fast and scorch the wood. I might want to use a dimmer controller on that blanket to keep it a little cooler than the main blanket.
Fred Tellier
Fred Tellier
PostPosted: Mon Jan 12, 2009 10:59 pm
I've bent with two blankets for quite a while now and run them with separate controllers but at the same settings. Blanket/slat/moist brown paper/wood/paper/slat/blanket.
Works great for me, very smooth, I wouldn't go back to one. I think if you could get equal temps with one controller it would be OK.
TJK
PostPosted: Tue Jan 13, 2009 4:14 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I used two separate PID controllers with two solid-state relays and two thermocouples. It's worth the extra money IMO.
Dave F.
Cambrian Guitars
PostPosted: Tue Jan 13, 2009 8:21 am
First name: Matt
Last Name: Meyer
City: Muscatine
State: Iowa
Thanks for all of the suggestions. I'll probably just bite the bullet and get another controller.
PostPosted: Tue Jan 13, 2009 2:27 pm
I contacted Tom Durr - the guy who made my controller/blanket system - and asked him about the possibility of modifying the control I bought to accomodate two blankets - the answer was no....
Im making another based on the design of the one I bought.... which will cost me alot less.. however.
Charlie
PostPosted: Wed Jan 14, 2009 12:31 am
First name: Nelson
Last Name: Palen
I run two blankets off one PID with a leaf type thermocouple on the wood.
The controller relay runs a solid state relay to carry the load.
Seems to work okay other than that flamed maple can be a bear.
Users browsing this forum: No registered users and 39 guests
